Farmall M front weights
I have never seen front rail wts for an M. Must be pretty rare,or don't exist at all? I have frequently seen front wheel wts. I even have a pair out back.Later,I'll go look in the 'optional equipment' section of my M manual.
In my original SuperM owners manual,only a front wheel wt is offered. No frame wts. The weigh 43 lbs each. Two per front wheel is the maximum recommended.
In the parts ads, #695743, there is a pair of weights for an M-450 called "Z" frame weights located in Indiana for $795.00 plus shipping.
Doesn't mater about the holes on the bolster corner. Frame weights that go on a SMTA will bolt on a M and SM. Bolt holes are there to match 2 bolt holes in the weights. Two 5/8 bolts is how they mounted on 300 to 450. In fact at one time I had some bolted on a SM I used with lift on rear.
