Company Logo Shop Now
TractorLinks.com
IH 350 utility - Where to fill differential fluid
craigsorensen
11-25-2019 21:04:26
Many questions
Is the tank below the seat part of the differential?
If not, where would I add oil to the differential?
I read that there is more then one pug. Is that true on the IH 350 utility?
Do I use HY-tran?
Is changing the hydraulic screen woth the effort? It looks like its under the heavy tank lid
The tractor has power steering and loader and backhoe. I have drained the plug between the axle and not sure if I should just fill up the tank under seat until it show full or do something else.
Brian AB
11-27-2019 10:48:48
 Re: IH 350 utility - Where to fill differential fluid in reply to craigsorensen, 11-25-2019 21:04:26
The transmission/differential fill plug is right beside the gear shift
Charlie M
11-26-2019 03:43:18
The tank under the seat is hydraulic only. Rear end oil is separate and the fill plug is between your legs when sitting on it in front of the seat. I can't remember how many drain plugs there are but people use hytran in the transmission as its also the oil for the TA. You may want to get a manual as it will tell where all the drain and fill plugs are and how many gallons each area holds. If you have a loader it must have its own hydraulic oil as the tractor doesn't hold enough to use a loader.
Duner Wi
11-26-2019 17:54:58
 Re: IH 350 utility - Where to fill differential fluid in reply to Charlie M, 11-26-2019 03:43:18
If you have TA I think you have 3 drain plugs and 2 level plugs.
Janicholson
11-26-2019 21:07:12
 Re: IH 350 utility - Where to fill differential fluid in reply to Duner Wi, 11-26-2019 17:54:58
And the IPTO is not included because it is also separate and has its own level plug. "drivers side" Jim
Copyright © 1997-2020 Yesterday's Tractor Co.
