Company Logo Shop Now
TractorLinks.com
Re: F20 getting oil in coolant
3LFarms
11-21-2019 03:24:29
I would think that with the radiator full, the water pressure would not let oil into the water jacket. I can definitely see where water would find it s way into an oil return if the head gasket is bad.
How much oil are we talking here? If you leave the oil pan empty and fill the radiator with coolant, If it is truly a bad head gasket or the sleeve o-ring is as, you should find coolant in the oil pan within a couple of hours.
On a similar note, When I assembled my engine, I was waiting a new manifold, so I taped off all the ports with 3" wide masking tape.
When I got to the point I could fill the radiator with water to check for leaks, I started finding water leaking into the oil pan.
Turns out that with the 3rd manifold stud back removed and the hole taped off, water was free flowing from a water jacket into the intake and it filled two cylinders with water and of course leaked past the rings. Once the stud was reinstalled with a little thread sealant, there was no water leak and no intake leak.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
