Company Logo Shop Now
TractorLinks.com
Re: Is M oil pump same as 450 diesel?
jhncp
11-18-2019 16:48:05
Looks you were right, the inspection camera was prably a big waste of money. I had another idea. If I put antifreeze in at certain levels in head, like 1/8" increments above head gasket, and keep testing with air pressure in injection opening, and listen for bubbling, will this help me dtermine if it's the head gasket or cracked head? Perhaps if the head is cracked it will need to be at a high level to bubble?
Janicholson
11-18-2019 20:39:28
 Re: Is M oil pump same as 450 diesel? in reply to jhncp, 11-18-2019 16:48:05
Heads can be assessed for cracks easily at the rebuilding end of the process. Flatness of the head surface, valve recession. and even the texture of the head can make a difference in keeping the gasket in tact for operation. I make sure the small oiling passage has an Oring (not standard to be there, and requires machining a counter bore for it) as they leak there. If it bubbles now, it just needs to be pulled. Jim
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
