Company Logo Shop Now
TractorLinks.com
Re: Is M oil pump same as 450 diesel?
CenTex Farmall
11-17-2019 21:36:23
Those engines have a huge amount of iron in the bottom end for the amount of power they put out. My guess is they didn't need as much oil pressure with so much bearing surface area spreading out the force.
Engineering desicion. You need enough pressure to push enough volume to the furthest point in the system. Any pressure beyond that and you're wasting energy and heating oil from bypassing it through the pressure regulator. The pressure gets the oil to the bearings but after that you need a combination of proper bearing clearance and oil weight and volume for the hydro-dynamic wedging action to occur. High oil pressure won't save a bottom end that's worn out or built too loose.
jhncp
11-18-2019 05:47:38
 Re: Is M oil pump same as 450 diesel? in reply to CenTex Farmall, 11-17-2019 21:36:23
This tractor also has oil thru rods so I would want to be sure there's adequite pressure for that. I don't know if the rings rely on oil from the oil running down from the oil thru rods.
Copyright © 1997-2020 Yesterday's Tractor Co.
