Company Logo Shop Now
TractorLinks.com
Re: Is M oil pump same as 450 diesel?
pete 23
11-17-2019 20:14:18
I never had the luxury of having a inspection scope while with dealership. Bought a cheap one a few years ago but pretty much useless. I did a lot of pressure testing of individual cylinders. I like that test to see if there is leakage, which cylinder it is in and also detect leaking rings, valves etc. Takes time to do it of course.
As for oil pressure, I don't know what the engineers reasons were but that engine has huge crankshaft and bearings and a lot of them for the cubic inch of engine. My old Chev was 14 psi, but with the dipper on the rod picking up the stream of oil directed at it from the tubes in oil pan , who knows how much pressure that rod bearing was absorbing.
jhncp
11-18-2019 05:40:31
 Re: Is M oil pump same as 450 diesel? in reply to pete 23, 11-17-2019 20:14:18
I put a air nozzle in injection hole #1 cyl. With valve closed and it's easily bubbling in radiater. If I don't know where it's leaking before I pull head off I dont know how to test head with it off or prably won't be able to tell the area of head gasket leaking.
Pete 23
11-18-2019 07:13:50
 Re: Is M oil pump same as 450 diesel? in reply to jhncp, 11-18-2019 05:40:31
True. But if you can get a scope in there and take a look, let us know how that worked. No experience with good scopes.
Copyright © 1997-2020 Yesterday's Tractor Co.
