Company Logo Shop Now
TractorLinks.com
Re: Is M oil pump same as 450 diesel?
jhncp
11-17-2019 13:03:22
Yes the engine oil pressure at the dash. I also have a problem with compression leaking into coolant and prably antifreeze leaking in cyl. #1. I just put new head gasket on. Is it possible head could be cracked? I tested with valves closed. I plan on buying a inspection camera I hopefully can fit thru injection hole.
Janicholson
11-17-2019 14:11:21
 Re: Is M oil pump same as 450 diesel? in reply to jhncp, 11-17-2019 13:03:22
Machining the head requires setting valve recession so the clearance and compression are maintained. They do crack if not shut down after idling on diesel far 5 min if worked hard, or at least 3 if warm. (no matter what others say) and then shutting off, leaving in diesel mode. The head oil passage is at the very front of the block on the right side of the front of the head. Jim
jhncp
11-19-2019 09:33:04
 Re: Is M oil pump same as 450 diesel? in reply to Janicholson, 11-17-2019 14:11:21
I assume you mean the gas side of the head? How big is this plug and can u test pressure there as well? Also what are the 4 pipe plugs for near the bottom of head on diesel side? Of course I couldnt get one out so I drill it out and noticed I drilled into a brass piece behind pipe plug.
Janicholson
11-21-2019 16:16:17
 Re: Is M oil pump same as 450 diesel? in reply to jhncp, 11-19-2019 09:33:04
Not an external port, but the passage from block to head for valve train oil. They can leak there and make a mess. Jim
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
