Company Logo Shop Now
TractorLinks.com
Re: Farmall 300 carb issues
The tractor vet
11-17-2019 08:15:02
Well first off i can guaranty the ing timing is OFF as what you may think is good it is not . Put a light on it and set to spec.'s , reset your valves because they are off . A hot valve set is anything over 70 degrees ambit air temp . Carb adjustment is best done with a warm engine and due to your ing timing being sofar advanced you are not going to get it . If the ideal speed it to high then you sucking off the main jet and not the ideal circuit . when i do a tune up on them i can get them to ideal down slow enough to darn near count the fan blades .
tractorsam
11-17-2019 11:22:57
 Re: Farmall 300 carb issues in reply to The tractor vet, 11-17-2019 08:15:02
Found a timing light, will give it a whirl tonight. I will do the valves again after I cut down a feeler gauge. The rocker arms really need to be dressed. Thanks, Sam
Copyright © 1997-2020 Yesterday's Tractor Co.
