Company Logo Shop Now
TractorLinks.com
Re: Small axle 460 wheels for 560
D Slater
11-17-2019 05:27:25
Don't know your location but you should be able to purchase some wheels for the 560 for less than machining. Same rims and rim clamps from the 460 will work on the 560 wheels. Lots of other models with similar wheels, even 460 tractors with 2.75 axles. 460 and 560 wheels should have a removable steel key with grove machined in the wheel. 560 type wheels will be stronger if a user tractor. Axle clamps use 7/8 bolts to the 3/4 diameter for the 2.5 axle. Do you have axles with one keyway? IH kept changing the castings to combat center hub cracking. Think the castings ending with R5 were the best in the 560 period. If you can get cheap 400 and 450 castings would be worth a try. If I remember correct the late 450 were up to R4 castings.
jhncp
11-17-2019 10:39:55
 Re: Small axle 460 wheels for 560 in reply to D Slater, 11-17-2019 05:27:25
1 keyway axles
Copyright © 1997-2020 Yesterday's Tractor Co.
