Company Logo Shop Now
TractorLinks.com
Re: how to use a grain drill
caterpillar guy
11-17-2019 01:38:44
Pretty much just put the seed in the seed box then either pull the rope to drop the seed discs, which in turn should engage the gears to plant. Pull the rope again when you want to stop planting. If it should happen to have a hydraulic lift set up the same thing for starting it to plant as the rope just with the hydraulic cylinder to raise and drop. If it has 2 boxes front and back one is for seed the other for fertilizer. The seed should have a vertical wheel or cup for the seed to meter through. The other might have a gear looking wheel that turns horizontally to sow fertilizer . Not all have both. Some even have a smaller box in the front of them for small seeds like Clover or alfalfa for seeding hay crops. They will all have a seed setting adjustment even the smaller box on the front. The front smaller box usually has short tubes to drop the hay like seeds just on top of the ground as they don't need much of a cover to make them root and grow.
Copyright © 1997-2020 Yesterday's Tractor Co.
