Company Logo Shop Now
TractorLinks.com
Re: Super H Hydraulic filler
Janicholson
11-16-2019 20:36:42
Using the belly pump as a reservoir is common. The original fill pipe came up out the top of the torque tube at the right hand side under the gas tank. If that is yours, the original cap like like a bakers hat or heavy knob. It was covering the washer/rod described below. Proper fill (if the original belly pump is still in there is 6 quarts. If removed and a plate is covering the pump hole. 7 quarts will do. Drain, fill and mark the stick. If using the system, it might need to be checked if hoses and cylinders take oil. Jim
Phil Tibbetts
11-17-2019 02:56:10
 Re: Super H Hydraulic filler in reply to Janicholson, 11-16-2019 20:36:42
Thanks Jim, I do not have the plate so I will just put in 6 quarts. I think my pipe is original.
Copyright © 1997-2020 Yesterday's Tractor Co.
