Company Logo Shop Now
TractorLinks.com
Small axle 460 wheels for 560
jhncp
11-16-2019 20:34:24
I bought a 560 with no wheels and my neighbor Is parting out small 460 with tires pretty cheap. Is there a tool that would work to bore out 1/4" (only 1/8" per side) without costing alot?
DR. EVIL
11-19-2019 12:54:11
 Re: Small axle 460 wheels for 560 in reply to jhncp, 11-16-2019 20:34:24
The holes thru the rear cast wheels were BROACHED. BORE AND KEYWAY ALL IN ONE PULL.
Just find some good usable 560 wheels. It's your cheapest option.
BarnyardEngineering
11-19-2019 04:07:44
One of those guys who line bores excavator pivot bushings in the field could probably rig up something to do the job. It would not be any cheaper than having it done at a machine shop, probably more expensive.
You're not going to find anything at the local Harbor Freight for $50 that's going to do the job.
I would still buy the 460 rims and tires, if they're any good. They'll fit right on the 560 centers when you find them.
Roger Tomfohrde
11-18-2019 17:11:29
Depending where you live I agree with getting the correct ones. Here the value of them has dropped off to what scrap will bring. Heck I have a set I'd like gone but it would cost more for the gas to haul them to a scrap yard than I would get so they a piled up under a 560.
ss55
11-18-2019 06:58:11
Check with salvage yards if they have any 560 wheels. You can probably find a set for somewhere between $50 to $250 depending how patient you are.
What would you consider "costing a lot"? It would probably cost well over $500 to have the 460 wheels re-machined, and the clamp bolts would still be the under size.
CenTex Farmall
11-17-2019 21:48:43
That would not be a fun job in a machine shop. You'd have to have one heck of a mill, like a Cincinnati number 5 to fit that on the table. Then they would have to somehow clamp it down after indicating off the existing bore to get it straight and true. An oil field type lathe with a plate could also work. Boring would be straight forward but you still have the keyway issue. You could grind a tool and use the carriage in and out to cut the keyway. Would work but very slow go.
I think you could buy an entire junk M-560 for what the job would cost (at least around here).
Pete 23
11-17-2019 08:53:31
No help here, just a comment.. We never sold a 460 with the small axle and we sold several early ones.
The tractor vet
11-17-2019 08:31:13
Early farmall 460's had 2 and 1/2 inch axles and a 560 has 2 and 3/4 axles , Nowlater 460's went with the 2 and 3/4 axles after they started breaking axles while under corn pickers and one with the heavy axle will work on a 560 but the small axle will not .
DeltaRed
11-17-2019 07:07:15
What you are wanting to do would be expencive.. Go find a junk M to use as a donor for rims and cast wheels. Or,a 400 or 450 would also fit.
D Slater
11-17-2019 05:27:25
Don't know your location but you should be able to purchase some wheels for the 560 for less than machining. Same rims and rim clamps from the 460 will work on the 560 wheels. Lots of other models with similar wheels, even 460 tractors with 2.75 axles. 460 and 560 wheels should have a removable steel key with grove machined in the wheel. 560 type wheels will be stronger if a user tractor. Axle clamps use 7/8 bolts to the 3/4 diameter for the 2.5 axle. Do you have axles with one keyway? IH kept changing the castings to combat center hub cracking. Think the castings ending with R5 were the best in the 560 period. If you can get cheap 400 and 450 castings would be worth a try. If I remember correct the late 450 were up to R4 castings.
jhncp
11-17-2019 10:39:55
 Re: Small axle 460 wheels for 560 in reply to D Slater, 11-17-2019 05:27:25
1 keyway axles
Phil Tibbetts
11-17-2019 02:59:48
It could be done in a machine shop but it would be expensive since most shops are charging 75 to 100 bucks per hour. IMO
caterpillar guy
11-17-2019 01:29:11
Just change the rims on to different castings that fit the 560 axles. To bore them out would require a way to cut a key to keep them from slipping on the axle when you try to pull with it. Castings from an M would be the drop center castings. If that is what you have for rims might work. They would not work on a double bevel rim.
jhncp
11-17-2019 03:51:11
 Re: Small axle 460 wheels for 560 in reply to caterpillar guy, 11-17-2019 01:29:11
I figured the keyway would still be plenty good since it would only be losing 1/8"
rustred
11-16-2019 22:47:56
No idea what u are referring to. Explain what u want to do.
FastFarmall
11-16-2019 23:49:55
 Re: Small axle 460 wheels for 560 in reply to rustred, 11-16-2019 22:47:56
He's wanting to slide the 460 hubs on the 560 axles. I really seriously don't think there is a machine with a cutter that would work.
rustred
11-17-2019 08:33:11
 Re: Small axle 460 wheels for 560 in reply to FastFarmall, 11-16-2019 23:49:55
ooh wow, need to find a big machine shop for a reamer that size, plus keyway would need to be cut is a possibility. it wont just be around the corner. plus if the wording and info would be more in the correct terminology person don't have to wonder. " enlarging rear wheel hub holes" . plus not the best thing to do as weakening the hub under heavy load. still not clear if using the 460's hub and rims or what combination.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
