Not that the weather has turned here in Northwestern Ontario, I have come upon a new issue with my British built 444. The last two times I have used it I have had an issue with the power steering. It functions perfectly turning to the right but will only go to the left about 10 degrees off centre. The first time it happened I presumed it was a bit of ice on it somewhere causing it to stop as it worked fine after about 20 minutes. Then I used the tractor a few days later and the same thing. I only needed to run it for 10 minutes and it never freed up but had the same symptoms: fully to the right but only 10 degrees to the left.
Both times were on days when the temperature was below freezing so I am guessing that it has something to do with water somewhere. Any help or guidance would be appreciated.
Scotty
Scotty
