Company Logo Shop Now
TractorLinks.com
Value of IH574
old
11-08-2019 21:00:43
So I was asked what a guy tractor was worth. Has front end loader. Gas runs ok but has boat gas tank on it due to rust in the stock tank. Tires are 75% or better all the way around. Come with a brush hog and maybe more. I told him as it sits with the hog $3000-5000. So am in in the ball park
gmcdeadhead
11-10-2019 15:18:52
 Re: Value of IH574 in reply to old, 11-08-2019 21:00:43
was the brake system a good design or not so good ? i would think from a owners view it would be bad because of the cost involved to fix them,
Mark Robke
11-10-2019 18:55:39
 Re: Value of IH574 in reply to gmcdeadhead, 11-10-2019 15:18:52
I am not really familiar with other tractors as much, but I worked on a lot of these for a couple of years after I retired. Brake jobs were the most common repair of all. Really not hard to do if you have a way of lifting rear tires,fuel tank,(which has to be drained),seat platform and the axles. I think it took me between 6 and 10 hrs,depending on circumstances. The parts for both sides would be less than $100. The o rings usually showed being flattened on the sides. Mark.
gmcdeadhead
11-10-2019 06:25:04
besides the gas tanks rusting out on those 574's, dont they have hydraulic issues? pto, brakes , steering issues. are those tractors a bad design or are they pretty good ?
Mark Robke
11-10-2019 11:27:20
 Re: Value of IH574 in reply to gmcdeadhead, 11-10-2019 06:25:04
About the main weakness on these tractors is the brakes. Some last longer than others, but the o ring seals usually fail, and you lose brakes. The main problem is all the labor involved in replacing the o rings because they are in the axles. Mark.
rustyfarmall
11-10-2019 05:29:13
With the jerry-rigged gas tank, I can't help but to wonder what else on that tractor might be jerry-rigged?
dgoodman2
11-10-2019 13:40:29
 Re: Value of IH574 in reply to rustyfarmall, 11-10-2019 05:29:13
Absolutely. No maintenance just keep her running.
old
11-10-2019 15:19:33
 Re: Value of IH574 in reply to dgoodman2, 11-10-2019 13:40:29
This guy is one of those who does oil changes etc. and all as he should or did up till he got COPD so bad he could not longer do much. Reason he took the old tank of was because of rust causing lot of problems
old
11-10-2019 08:16:36
Very little from what I can see. I've used it a few times on the guys place brush hogging and also a bit of loader work and it run fine other then a bit on the rich side
Mark Robke
11-09-2019 12:19:05
So how did he mount the boat gas tank on the tractor? I can't really visualize there being any place that it would not be awkward/clumsy and in the way. Those tractors have a tendency to rust between the sides and the fenders, especially ones that get parked outside. And I believe these tanks are scarce too. Might be a good aftermarket market for them-if someone remanufactured them. Mark.
old
11-09-2019 14:26:52
 Re: Value of IH574 in reply to Mark Robke, 11-09-2019 12:19:05
It has a sort rops/brush guard behind the seat and he made a bracket for the tank to sit on
Janicholson
11-09-2019 05:47:20
Depending on hours, and metal condition 4 to 7K (opinion sight unseen) Jim
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2020 Yesterday's Tractor Co.
