Company Logo Shop Now
TractorLinks.com
Re: International 660 hydraulic failure
Tony Williamson
11-07-2019 01:31:55
Rustered you are saying the drain is the plug near the tow hitch pivot that drains all 3 compartments and the fill point is the plate with 3 bolts that uncovers the top edge of a crown wheel. I did see a square headed plug a few inches up on the left of the gear case and used that as a level guide the other day.
Tony
rustred
11-07-2019 17:33:10
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-07-2019 01:31:55
that is all correct. you can drive the tractor up on some planks or what ever to get the front higher up for a better drain. to flush it add some cheap hyd. oil with some diesel like 5 gallons or so and drive it around a bit but not a lot. then drain again. plus drain those other places you mentioned.
Tony Williamson
11-11-2019 01:48:49
 Re: International 660 hydraulic failure in reply to rustred, 11-07-2019 17:33:10
I pulled the pump yesterday, now looking for a replacement but so far getting prices around the $2000 for hydraulic and power steer pump as both are as bad as each other. I did find a used unit but am wary as there is no way of knowing if it is much better than what I already have.
Tony
Tony Williamson
12-22-2019 02:13:03
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-11-2019 01:48:49
Put the new pumps on yesterday, hydraulics worked as designed but the power steer ram leaks and would only turn left (50% win).
Pulled the ram down today to find the shaft seal only half there and the shaft missing chrome in several places and the cylinder with a few scratches.
So basically now looking for a steering ram.
Tony
Copyright © 1997-2020 Yesterday's Tractor Co.
