Company Logo Shop Now
Re: International 660 hydraulic failure
rustred
11-06-2019 19:40:12
think its about 17 gallons of oil u need for a change. better get that milky stuff out of there. the actual drain is at the rear of tractor. your fill is remove the plate right of gear shift. oil level is at plug on left side of trans.
Tony Williamson
11-07-2019 01:31:55
 Re: International 660 hydraulic failure in reply to rustred, 11-06-2019 19:40:12
Rustered you are saying the drain is the plug near the tow hitch pivot that drains all 3 compartments and the fill point is the plate with 3 bolts that uncovers the top edge of a crown wheel. I did see a square headed plug a few inches up on the left of the gear case and used that as a level guide the other day.
Tony
rustred
11-07-2019 17:33:10
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-07-2019 01:31:55
that is all correct. you can drive the tractor up on some planks or what ever to get the front higher up for a better drain. to flush it add some cheap hyd. oil with some diesel like 5 gallons or so and drive it around a bit but not a lot. then drain again. plus drain those other places you mentioned.
Tony Williamson
11-11-2019 01:48:49
 Re: International 660 hydraulic failure in reply to rustred, 11-07-2019 17:33:10
I pulled the pump yesterday, now looking for a replacement but so far getting prices around the $2000 for hydraulic and power steer pump as both are as bad as each other. I did find a used unit but am wary as there is no way of knowing if it is much better than what I already have.
Tony
Tony Williamson
12-22-2019 02:13:03
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-11-2019 01:48:49
Put the new pumps on yesterday, hydraulics worked as designed but the power steer ram leaks and would only turn left (50% win).
Pulled the ram down today to find the shaft seal only half there and the shaft missing chrome in several places and the cylinder with a few scratches.
So basically now looking for a steering ram.
Tony
Copyright © 1997-2020 Yesterday's Tractor Co.
