Company Logo Shop Now
M quitting-intermittent -------update
Ellis Kinney
11-06-2019 06:15:24
It is funny how you miss something. My M is what I consider perfect with new engine, axle bearings all new electronics, 12 volt and lots of other stuff. But in all my updates and overhauls I never even considered a new push/pull kill switch. After I posted my problem several good ideas were floated, but Charlie M suggested the switch. Since that was the easiest place to start I wiggled it and pinched the wires the next time the tractor tried to quit. Varoom!!! Just wanted to let everybody know how it worked out. Thanks, Ellis
old
11-06-2019 08:08:31
 Re: M quitting-intermittent -------update in reply to Ellis Kinney, 11-06-2019 06:15:24
Problem like that is why I say hot wire it. If it works hot wired then the problem is from the coil back to the battery. If does not fix it then the problem is in the distributor
Charlie M
11-06-2019 07:30:50
I've had my share of experiences with push/pull switches- includes wires rusting off, pulling the entire button out of its holder and having a bad spot on the switch. Glad it worked out for you.
rustyfarmall
11-06-2019 06:49:03
I had to replace that switch on my M. After market type. Doesn't have the same appearance as the original, but it works.
Ellis Kinney
11-06-2019 12:15:49
 Re: M quitting-intermittent -------update in reply to rustyfarmall, 11-06-2019 06:49:03
I had a couple of extras stockpiled in my cabinet. They are new and don't look the same but it ain't a show tractor. It earns its keep every summer. Ellis
Copyright © 1997-2020 Yesterday's Tractor Co.
