Ken Christopherson
Hello all - thought you would like to get an update on the transmission countershaft removal. The coupler nut suffered as well as the front shaft bearing,
but we got the shaft out without too much carnage. I am going to replace the shaft due to the several heating cycles that it was subject to in order to try
to remove the nut.
Got a new/used shaft coming with coupler and front and rear bearings. Going back together it will get all new gaskets, seals, a new 3rd/4th drive gear and
4th/5th slider. All bearings in the rear end seem really nice, and were most likely replaced when the rear end was tore down to braze the crack in the rear.
I am also replacing the entire rear casing due to the crack expanding towards the right side where the axle housing bolts to the housing (the red circled
area), and having more issues on the original. The replacement is not too far off from the original, though. They were cast about 12 months apart.
Anyhow, I hope you all are really enjoying this project as much as I am - and I want to say THANK YOU for all of your help and support in it. It really is
for a good cause, and for a guy that started on these forums at the age of 12 (now 33)... It is a great community to be a part of. If you can, don't forget
to check out the GoFundMe link in the video - all support is appreciated and goes towards the cause. Cleaning and reassembly is next!
Transmission Teardown SUCCESS
to remove the nut.
