Company Logo Shop Now
TractorLinks.com
Re: International 660 hydraulic failure
BarnyardEngineering
11-05-2019 04:36:04
Unfortunately you can hope all you want but most likely that's what you're going to have to do. Starving the pump for oil likely burned it up.
All you can do is put a new filter in, change the oil, and cross your fingers.
Even if you knew where the pump picked up the oil from you can't see in there anyway, and all the oil is shared between the transmission, TA housing, differential housing, and final drives.
When you dump the oil to change it you will see if it's sludgy.
Tony Williamson
11-05-2019 23:23:53
 Re: International 660 hydraulic failure in reply to BarnyardEngineering, 11-05-2019 04:36:04
I realize the blocked filter may well have caused to pump to run dry and start eating itself.
I have drained about 13 litres of a milky type oil from a small plug almost directly under the steering box and put about 22 litres back into the compartment housing the main transmission gearing thinking the transmission and differential had a oil passage between apart from the pipe to the hydraulic filter (that I found when looking for oil reserve). I also drained about 2 litres from a plug just behind the clutch cavity but cant find a fill point to replenish this.
There is another drain plug near where the tow hitch pivots but I havent seen anything the looks like a fill/level point so am reluctant to drain that yet. There is also a drain and fill point at the pto shaft but that appears to be a separate unit with different oil to the drains more forward.
Tony
rustred
11-06-2019 19:40:12
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-05-2019 23:23:53
think its about 17 gallons of oil u need for a change. better get that milky stuff out of there. the actual drain is at the rear of tractor. your fill is remove the plate right of gear shift. oil level is at plug on left side of trans.
Tony Williamson
11-07-2019 01:31:55
 Re: International 660 hydraulic failure in reply to rustred, 11-06-2019 19:40:12
Rustered you are saying the drain is the plug near the tow hitch pivot that drains all 3 compartments and the fill point is the plate with 3 bolts that uncovers the top edge of a crown wheel. I did see a square headed plug a few inches up on the left of the gear case and used that as a level guide the other day.
Tony
rustred
11-07-2019 17:33:10
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-07-2019 01:31:55
that is all correct. you can drive the tractor up on some planks or what ever to get the front higher up for a better drain. to flush it add some cheap hyd. oil with some diesel like 5 gallons or so and drive it around a bit but not a lot. then drain again. plus drain those other places you mentioned.
Tony Williamson
11-11-2019 01:48:49
 Re: International 660 hydraulic failure in reply to rustred, 11-07-2019 17:33:10
I pulled the pump yesterday, now looking for a replacement but so far getting prices around the $2000 for hydraulic and power steer pump as both are as bad as each other. I did find a used unit but am wary as there is no way of knowing if it is much better than what I already have.
Tony
Tony Williamson
12-22-2019 02:13:03
 Re: International 660 hydraulic failure in reply to Tony Williamson, 11-11-2019 01:48:49
Put the new pumps on yesterday, hydraulics worked as designed but the power steer ram leaks and would only turn left (50% win).
Pulled the ram down today to find the shaft seal only half there and the shaft missing chrome in several places and the cylinder with a few scratches.
So basically now looking for a steering ram.
Tony
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
