Company Logo Shop Now
TractorLinks.com
Re: IH574 gas loosing hyd oil
caterpillar guy
11-05-2019 01:37:09
If he is using the remote coupler on the back the o0rings in the couplers can leak if the o-rings get chipped or cut. or if the tips in the coupler get damaged. The steering leak at the wheel is an easy fix. You can do it without pulling the hand pump. If it is leaking down on the bottom end than it will have to come out to fix that. The brakes master cylinders may leak though not real likely. I would suspect maybe the brake piston, inside the wheel and trans housing is leaking.
old
11-05-2019 08:09:21
 Re: IH574 gas loosing hyd oil in reply to caterpillar guy, 11-05-2019 01:37:09
I did not look at the wheels for oil guess I'll have to next time I go there. I did look it over pretty good and find no place where there is fresh oil leaking so sort of hard to figure out with out signs. As for the steering seal at the top you say easy to fix so explain please my 584 leaks there
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
