Company Logo Shop Now
Re: Super C Chipped Block - Is It Ok?
used red mn
11-04-2019 22:13:59
Hello nice guy, welcome to YT! I agree that this would probably not cause you any issues. However, if it would make you feel better you could fill in the defect with JB weld or the like. Clean the area real good with a rotary wire brush probably want to get that cast primer/sealer off of the area. Clean it up with a shot of carb cleaner or acetone. Cut a piece of milk jug to fit in the o-ring groove, wedge it in there with match sticks. But before you stick it in there rub it with candle wax so the epoxy won’t stick to it. I would over lap it around the edge of the defect 3/16 - 1/4” about a 1/16” thick on the overlap part. After it is set a little touch up in the groove with a cut off wheel or Dremel and you’ll be set. Good Luck! Rick
Copyright © 1997-2020 Yesterday's Tractor Co.
