Company Logo Shop Now
TractorLinks.com
340 International alternator conversion
MeanGene1
11-04-2019 17:42:55
Wondering if anyone has done this particular conversion, as the front lower bolt goes into a blind tapped hole, so not as easy as usual, can't just run a long bolt and spacers. The regular lower flange on the GM 1-wire I have is much too thick, but if I were to flip it upside down and drill the flange that is usually the adjuster side, and machine it a little thinner, it would line up, and just use a bolt and nut on the adjuster. As I also have a 330 with the same engine, wondering if anyone has found an alternator that will fit without mods- probably why I am not finding a kit for these particular tractors. PO of the 340 had installed a 12V bat at neg ground and ran it a long time, so it's generator is dead, Just pulled the one off the 330, which has a reman sticker, wishful thinking that it will work at original 6V pos ground, but would like to go to 12V alt instead. I see a few alts on ebay that came off 340s with some kinda hokey fabbed up brackets, trying to avoid that if possible
460anger
11-05-2019 16:01:37
 Re: 340 International alternator conversion in reply to MeanGene1, 11-04-2019 17:42:55
you want the one made for farmall 140 super c one wont work the 140 mounts the alternator higher if you compare them you will see the 140 legs are longer than the super c
MeanGene1
11-06-2019 08:26:24
 Re: 340 International alternator conversion in reply to 460anger, 11-05-2019 16:01:37
Thanks- sounds like you have done this yourself? That's what I was looking for, been there done that experience. I will take a look at that one and compare. Both tractors have loaders, 330 a Wagner step-through, and 340 a big Farmhand that was probably made for M type tractors, but both have pretty good clearance around the generator. Even if the gennie off the 330 works, I would rather spend money on an alt convert than buying a 6V battery
MeanGene1
11-05-2019 13:15:58
Well, this bracket kit says Super C etc., but does not say 340 or 330- seems like if it would fit, they would say so. It does appear that it might, with the two horizontal holes and the 2" space for the alt mount- just like to hear from someone who has actually done it before coughing up 50 clams for the brackets
https://www.yesterdaystractors.com/Farmall-Super-C_Alternator-Bracket-Kit_IHALTBKIT.html
BarnyardEngineering
11-05-2019 04:58:42
The C-135 is just a bored out version of a Super C engine, and the A/B/C series tractors are just about the easiest to bolt an alternator on to that there are... Not sure what would be different on yours.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
