Instrument Cluster Lights
I recently bought a International 2504, none of the lights worked and a lot of the wiring wasn't hooked up. I'm going through and adding lights and trying to get all the gauges to work again. My question is
does anyone know the bulb size for the oil/amp tellite? Also the bulb size for the fuel and temp light? Also has anyone ever install aftermarket sockets for any of those lights? Any help or guidance would be
appreciated.
Thanks!!
Th org. lite bulbs for oil and amps was a Blinky bulb and don't ask me the Bulb number as i have long for got . Now as for dash lighting i use and 1895 bulb as it is as heavy duty #57 bulb . Yes i have used light sockets other then OEM and where i us to get them was out of big truck junk yards when i went harvesting the plug in wire connections to repair the wiring systems on I H tractors and also Oliver tractors .Also a great place to find good gauges as old semi's and big trucks had really good mechanical gauges .
