656 hydro drive
bass
can someone educate me on how to use the hydro drive on a 656 and where is reverse? this is going to be all new to me.
bass
ok if the lever on the left is f/r and the lever on the right is hi/lo then where is the leaver for the ta?
I found the lever for the pto ok. the sN tag has an S suffix meaning it has a ta but where is the handle.....
bass
Right side leaver is High ,neutral, Low range, left is Forward ,neutral, Reverse. That is if you have hand
controls,they also made foot operated forward-reverse. Hard pulling should be done in the Blue rang(left side)
Also the left "clutch" pedal is called a foot and inch pedal. Just drive it and get a feel for it,kinda like a
Hydro garden tractor. Now after saying all of this,I am talking about an Utility model,I have never been on a row
crop.
Well, can't be a Hydrostatic drive tractor and have a Torque Amplifier. The S on serial number tag
stands for Torque Amplifier.
In other words, we are talking about two different situations here so need a little more information
about your tractor.
I bought a new Hydro 70,Farmall, there is no TA, why would u want one,just make sure the Hy-Tran fluid is changed according to the book! That Hy-Tran fluid can only absorb so much water!
