Dave H (MI)
I had asked about replacing a seal on the live hydraulic pump because I have oil in the distributor. I understand about setting #1 to top dead center and the soda straw in the spark plug hole...BUT...how do I know this is TDC on ignition and not exhaust? It matters I would think right? I removed a distributor one time only, maybe 15-20 years ago on a Farmall B. Isn't there a mark or such on the flywheel that I need to mark with some white paint or marker so that I make sure it stays there during the repair? I cannot do this repair right now because the tractor died outside and the weather is just too chancy, but I want to use the winter months to make sure I understand the process before I screw up one the hardest working tractors I own.
