Woods 59LB mower deck again...
treeman53
When reinstalling the pulleys on to the spindles, how should they be aligned? I assume left (from front) should be aligned directly to center of triple center pulley. Should the right pulley be aligned to top of center pulley, or between top and bottom of center pulley?
Manual is available on Woods site. It will give you the measurements, I believe from deck for each pulley. Several years ago I cured one of eating belts that had pulleys installed by eyeball method by a previous so called repair person.
