Which model Harrow?
dep
Hi, I know this is a pretty common IH harrow, but what model is it? Is 6?. Did they also come in hydraulic version?
not from factory but there were kits to add on and using a one way cycl to put the disc out of gear you relieved the cycl for the disc to go into gear then used pressure to put it out of gear we had one on the new 8ft tandem in 49 local weld shop made them and sold them
I think it is a McCormick No. 10-A Disk Harrow. We had one that was 7? and one that was 9?. The 9? had a hydraulic cylinder on it. The owners manual I have for it shows a remote control cylinder adapter package, the power gang angling attachment (seen in your photo) and the independent gang angling attachment. It shows other attachments such as a hitch for trailing implements ( that we had on our 9?) full blade scrapers, center tooth attachment, hydraulic ?lift-all? de-angling device (power or manual set) depth gauges, and even transport truck (steel wheels). The date on the manual is 11-30-49.
