706 farmall hydraulic filter
Help please...
I just changed the hydraulic filter on my 706 and I cant get the loader to work properly.
the power steering, brakes, and TA work ok but not the loader...It does move but it acts like I have air in the system... Any advice?
(quoted from post at 00:31:03 01/13/10) Help please...
Did the loader work Okay before you changed the filter?
What are the symptoms you are having that cause you to believe there is air trapped in the loader system? Air in the system should not keep it from lifting but will cause the cylinders to act like they are mounted on springs.
The 706 uses a separate pump for the hitch and auxiliary valves. It is likely that you have a problem in the rear system that still allows the front system to function normally. If you give us a better description of your problems we will be able to suggest some things to look at to discover the problem.
The loader worked just fine before I changed the filter. I changed it because I was having a little trouble with the brakes, power steering and TA when it was very cold. on my test run the brakes and power steering and TA worked much better but the loader almost did not move at all.
Thank you very much for your reply.
I have the same problem. k@dows. I didnt have steering until I changed the hydraulic filter. Overfilled hydraulics to start then changed filter. Now loader works but in like on springs. I am looking for advise.
I have the same problem. k@dows. I didnt have steering until I changed the hydraulic filter. Overfilled hydraulics to start then changed filter. Now steering works but loader is acting like on springs. I am looking for advise.
