856 front axle
AGR538
Recently bought an 856. It has the skinny tires on front axle and I want to put on the wider rims and tires. Will wider rims fit the same hubs? Also, the parts manuals show a heavy duty axle. Did these axles have larger hubs?
The bolt patterns are standard, either 6 or 8 hole. "Implement wheel" patterns.
Only difference in the "heavy duty" front axle is the 8 bolt hubs. Everything else is the same, right down to the last cotter key.
What's important on these tractors is the offset. You can't just grab any wheel and put it on as it will rub the knee.
