Dave H (MI)
This is a great tractor. Spent many days on it cutting, raking and baling. This fall I brought it home and parked it on the drive. Went out to start it and it fired up and stalled right away. Battery box was completely full of water so I drained it and charged up the battery. Started and then died right away. Now it won't fire at all, just cranks over. Plenty of gas. I pulled the center wire off the distributor and it was my impression that the spark was not the greatest when held next to a ground. Would the symptoms I described be a sign of a weak or failing coil? It hasn't done the typical run 20 minutes and stall bit that I am familiar with on failing coils. Contacts under the cap were really carboned up. Maybe it needs a kit in the distributor? It was running fine...hate to fix anything that ain't broke.
