bmgreenawalt
New User
My dad has a 1964 International Harvester 424 that has been in his barn for a while now. He bought a 584 to take care of everything he was using the 424 for, along with others and because of that, he gave up on fixing it.
It got left out for a month or so while we were building the barn. I can't remember what the weather was like, but it's safe to say there was rain or something because the motor appears to have seized up.
It used to be where you'd turn it over and it'd start basically instantly. He had the starter rebuilt because he removed it and the clutch drive wouldn't spring up, and after that, he ended up buying a new starter all together.
He also mentioned trying to pull start it in a high gear. No matter how he tried it, the wheels are just stuck and will not spin when in gear.
Now this is the first time I'm going to look at it, and I found that after testing the starter, and replacing the battery, it will not crank. When you try to engage the starter, it just gives an awful low groaning/grinding noise. This leads me to believe the motor has seized up.
I've read multiple things on here, among other forums that have suggested pouring all sorts of lubricants down the cylinders from marvel mystery oil to brake fluid, etc.
Just wondering if anyone has any ideas or has ever dealt with this before. Looking for some insight before I go tearing the engine apart.
Unfortunately, I'm 200 miles away from him until I move next week. I was going to attempt to turn the motor by hand.
I appreciate any help!
