BN fan removal update
Dave BN
Got the new fan on the BN last night. I removed the hood, grill, fan shroud, top radiator bracket and the
upper water neck. It is almost impossable to get it all back togather as the water neck gasket has to be
kept in place while you hold the water neck and fan and slip the upper radiator hose on while installing the
3 bolts for the upper water neck. Had to have the wife help me for that part. This procedure worked but
might be just as easy to remove the whole radiator like the book says.
Thanks for the previous replies.
Dave
Thanks for the advice Ken but I took her out to dinner just last month, Haha.
By the way, it was for our 40th anniversary. How time flys!
Dave
next time it will go better if you had loosend up the nuts on the bottom of the radiator so it would tilt out would have made it mush easier
