706_from-da_woods
I recovered a 706 Diesel that sat for over 30 years in the woods.I got it running, new belts, hoses, tires , wiring, etc - a ton of work.
Now the steering quit. No response while running unless I spin it a lot, then it turns, but is stiff - that was working fine. Now that I
have it moving I also don't have any brakes at all. Not sure if they worked before the steering issue as I had one tire and 3 rims on the
ground then.I added Hydraulic fluid and bled the brakes. What would cause both issues?
