Jerry Gilliam
Does the fuel tank in a 656 gas have a strainer inside the tank and can you
remove it The motor seems to run out of fuel and stops, Wait a minute and it starts up. Pulling choke out makes it run longer for about 30 seconds I have took the lines off from the carburetor fuel bowl. Blown thru , Seems all clear but not letting the tank flow good
Thanks in advance
Thanks in advance
