Ken Christopherson
Hello all! Well, we have made a bit of progress on the 1942 H. Last night we buttoned up the engine for good. All that is left is to adjust the valves, mount the manifold, carb and magneto which I will do when the engine is back in the tractor. A fresh governor rebuild, water pump rebuild, top to bottom sleeves, pistons, bearings, seals, valves, guides, springs, seats, etc.... Nearly everything has been done. The only thing we didn't have to do was the cam bearings which measured out just fine.
Next on the list is the front bolster rebuild. We have a new lower shaft with worm gear, new sector gear, new U-joint, new steering wheel, all new seals, bearings and bushings. My question for everyone is - are there any tips to rebuilding the bolster? The only thing that I am somewhat nervous about are removing those big bushings. Any tips or tricks are greatly appreciated!
After the bolster, all that is left is all new seals in the rear end and hydraulic pump. Then it is off to sandblast, prime, and paint!
