paticpatic
I finally had my 1949 Farmall H running. We rode it on 3 different days for about 30 minutes each ride. The last ride, my wife noticed oil on the right side of the engine. The pressure was normally at 60 psi, but when I checked it, it was only 10 psi. I think and hope it is the Oil Filter Assembly. I removed the cover and found 2 separate rubber O-Rings. The filter was replaced recently, but I wonder if 2 O-Rings is normal? Should I put it back together with 1 or 2 O-Rings? Any recommendations on How Tight should I tighten to Top Bolt of the Assembly? Again, thanks for the help Kevin
