Goose
How can I pop the steering sector gear loose from the upper bolster shaft on an H?
It's a 360 degree gear, and all I want to do is turn it 180 degrees so it's meshing fresh teeth.
I'm thinking if I jacked the front end up just a tad and tapped on the upper end of the shaft after loosening the nut that holds the gear on the shaft it might pop loose.
the only other one of these I've had occasion to flip was on an M, and that gear was loose when I took the nut off.
Thanks in advance for any help.
