Cub Governor Problems
My cub tractor you can move the throttle lever back and forth and it will make the engine react... Now when I am working it for a while and stop for a break I cannot get the engine to slow down, I can move the throttle lever forward and backwards and it doesn't want to slow down,.. If I turn the engine OFF the governor will release it to normal. I took the governor off a couple of weeks ago to clean it per you tube video, I did not adjust anything. What is the set screw bolt in front of the governor for?
