B Steering Gear Assembly
Red Raider
04-10-2001 19:40:59
Is there a special procedure to separate the gear, retainers, bearings, and seals from the steering assembly? I have the shaft and washer out, but the top bearing is really tight. Can a puller be used?
Dave G
04-11-2001 19:37:40
 Re: B Steering Gear Assembly in reply to Red Raider, 04-10-2001 19:40:59
Hey Red - I know just what you are talking about. I recently did 3 B's. The first time I broke the bottom casting with the turning stop lugs on. Here is what I learned: To get the top bearing off I use my press and block up under the gear and press on the top. If you need to heat up the bearing a little. To get the 2nd bearing (big one on bottom) I flip the assembly upside down and press on the bottom casting (plate with turning stop ears)using wood blocks position as close to the center as possible in order not to break it. This is what works for me. It sure feels good to get that seal replaced so it will hold oil again. I'd check & replace bearings if needed while your at it. Heat bearing and freeze shaft to put back together. Make sure you have gaskets, etc. in place before putting bearing back on.
Red Raider
04-12-2001 05:54:04
 Re: Re: B Steering Gear Assembly in reply to Dave G, 04-11-2001 19:37:40
Thanks Dave & Gene. I'll have to take it in since I don't have a press. Cast parts are tough but can't take concentrated stresses or blows, so I have to be careful here. I know from experience with a Cub crank pulley!
gene b
04-11-2001 02:50:10
loosen the nut on the bottom and the whole thing will come apart when the nut is off you will have a rod with a large head havent had any problems getting the rest of the stuff apart I am asuming you are replacing the seal on the pedestal sure makes them steer better when you are done
Red Raider
04-11-2001 06:22:05
 Re: Re: B Steering Gear Assembly in reply to gene b, 04-11-2001 02:50:10
I did remove the nut and shaft, but it's not separating. If the top bearing isn't being held on with a snap ring or anything, it should slip right off. I hate to pull on a bearing to get this thing apart.
gene b
04-11-2001 20:08:40
 Re: Re: Re: B Steering Gear Assembly in reply to Red Raider, 04-11-2001 06:22:05
boy I must be lucky have did 5 the last few years and havent had any problems at all that is a thrust bearing and not made to be pulled guess would try and press it off kinda hard to replace the seal without removing the bngs good luck
Dave G
04-12-2001 19:34:21
 Re: Re: Re: Re: B Steering Gear Assembly in reply to gene b, 04-11-2001 20:08:40
Yea - I don't completely understand it either. I guy I get parts from says they come right off, but they sure haven't for me. Must be some variation in the shaft diameter.
