Farmall & IHC Tractors Discussion Forum |
Tach cable help
Author |
[Modern View] |
JeffPhillips
09-13-2019 21:24:30
I need some help finding a tach cable for a diesel 3414. Most cables listed for this machine specify that they are for the gas variant, not the diesel. I finally found one for a B414, which while being of the correct configuration, is only 36" long compared to the required 48" length.
The parts manual lists it as two parts
Shaft: 3049482r91
Core: 3049371r1
Can anyone point me in the right direction?
jimb2
09-14-2019 06:19:19
Re: Tach cable help in reply to JeffPhillips, 09-13-2019 21:24:30
The usual failure was the tach drive mechanism that ran off the top of the oil pump shaft on the BD-154 Diesel. Also if you live in a colder climate make sure that the tach cable has a coating of a light grease so that moisture doesn't collect and allow tach cable to freeze to the outer cable.
JeffPhillips
09-13-2019 22:44:27
Please forgive me, I know very little about tach cables. With the product suggested in the above link, I see no reference to the tractor model nor to the listed parts numbers. How are you cross referencing the model numbers to know it will work?
Bob
09-13-2019 22:28:21
Bob
09-13-2019 22:26:03
How about the one linked below? If NOT, what ends do you need?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
