I took the 2nd alt back and they gave me another one. I Installed it and connected the
excite wire to #1 terminal WITH the diode installed white band toward alt.It started
charing immediately 14.2volts then backed down to 13.2 reading taken at the battery Boy I
thought finally everything is fine When I turned the ign sw off the tractor kept running. I
removed the excite wire and it shut off. Iam using the hot side of coil for excite wire the
alt must be backfeeding the coil to keep it running I THought that's what the diode was for
I temporarily hooked the excite wire up to a toggle sw and it worked fine. Any ideas
Thanks Bob
Thanks Bob
