It runs somewhat in low speed. It has power even tho running erratically. I plowed a 3 acre field today starting at 1030 A and with a 2 hr break at noon finished at 6 45. This field may have never been plowed before, and I now get where Okies say breaking ground rather than plowing it. IF I open it up, it runs terrible, back fires and has no power. I put a new kit in it last year. Ive had it apart 4 times now, both to spray carb cleaner in it and to blow it out. Ive taken out the fuel bowl, which I had installed a 1in riser pipe in it to keep any scale from getting over the bowl hole. I took it all apart and blowed through everything. Ive got a new filter on it. Ive got it set at 2 turns for each adjustment. I need to get this cleared up as I need to disc and harrow this ground before the fall rains commence. Thanks for any help forehand.
