Farmall super m pto questions
JOCCO
Need some information a late super m/md has the round type pto housing. Lever is a hand lever similar to the Torque amp lever. Is this the live pto and how does it work? Much different than the older m with just a rod you pull. Thanks for any replies from farmall people.
Does it look like this one? If so it's a independent PTO. Not counting a manual disconnect under the tractor center housing the input shaft of the PTO is turning anytime the engine is running. Lever is to turn it off and on. Would be a Super MTA serial number 60,001 and higher. Louisville built SM with a higher number not included.
If that tractor is indeed a diesel and it has a PTO similar to the one shown by D Slater with a right hand PTO control lever that tractor would be a Super MTA diesel. It can be a very sought after tractor by collectors.
