Company Logo Shop Now
TractorLinks.com
Adjustable fan belt sheave on 53 Super H
dwashebek
09-11-2019 18:29:40
I have a 53 Super H with a cracked fan belt sheave. I知 thinking about changing the entire water pump as a new sheave comes with a new water pump. I知 not sure how to remove the fan or the sheave or the water pump for that matter. Do I need to remove the hood and front cowl? Thanks.
caterpillar guy
09-12-2019 11:37:51
 Re: Adjustable fan belt sheave on 53 Super H in reply to dwashebek, 09-11-2019 18:29:40
I would just change the sheave. With the fan off it should just unscrew then screw the new one on. The fan should just unbolt with 4 bolts. The bracket with the springs have a set screw to hold it on the shaft then like said.
pete 23
09-12-2019 19:26:22
 Re: Adjustable fan belt sheave on 53 Super H in reply to caterpillar guy, 09-12-2019 11:37:51
The M water pump adjustable sheave will screw off when you take the front plate off BUT, an H or Super H water pump has a pressed on rear sheave that has to come off to replace the adjustable one. Also, has a pin through the flange anchoring it in place and bearings have to come out to drive that pin out and retrieve the pin.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
