So I put a rebuilt clutch disk (disk hub facing towards transmission), rebuilt pressure plate, and new throwout bearing in a 1975 Farmall 140 the other day and put the tractor back together. I didn't think anything of it but it was a little difficult pulling the 2 halves back together. Once buttoned back up, the clutch pedal had zero free play and I thought I would be able to adjust it from the rear hand-hole like it shows in the manual. I've ran both nuts forward and backwards and now they are both "loose" from the bracket on the linkage rod and still Zero free play. Looking at the throwout bearing from the other handhole (looking straight up) it looks like there is a 3/16 - 1/4 inch gap between TO Bearing and the rear of the sleeve it fits on. The TO bearing is pressing down on the pressure plate fingers too. I'm sure this is my problem, but now that I have the tractor split apart again, I want to make sure that I don't need to check or do anything else. PLEASE HELP
