Transmission Drain Plug on Farmall 340
Bookman
Anybody happen to know the parts number on a Farmall 340 transmission drain plug? I have a chip in mine and want to replace it. Looked in the parts catalog and they give several parts numbers. Went to the local Case-IH dealer and he could not figure it out either. Next step is to measure mine and take it in, but I am not wanting to take it out right now (and drain the transmission). Thanks in advance. It is a late 1960 model (serial 6620).
I believe mine are pipe plugs also. They have a opening that I insert a 3/8 drive extension and ratchet to get out. I take out all three when i change fluid and filter. I change oil in the PTO at the same time, it has it's own drain.
Putter and Gary, Thanks. I measured and it must be about 1 1/4" pipe plug. I will try the hardware store today. Thanks again.
