burnsg2003
My starter on the super H does not engage the flywheel. I took the starter off and use battery jumpers to activate the starter. The gear seems to move outward. The one thing I notice is I can move the starter gear out but should it not lock at the end of the shaft. I actually took the starter apart and removed the starter motor. There is a heavier spring held in place by two rings and bolts. I am not figuring out how this works is this spring suppose to expand and push out the starter gear. If someone can explain how this all works would help me a great deal. The starter gear and flywheel are worn some but teeth good enough they should be engaging. The started has been converted to 12 volts. Thanks for any help that anyone can give me.
