Company Logo Shop Now
TractorLinks.com
HELP! Farmall 434 needs remotes!!!
DieselAlbie
09-10-2019 08:10:51
Does anyone have any advice, pictures, or knowledge about installing a set of remotes on a farmall 434
DieselAlbie
09-11-2019 17:39:00
 Re: HELP! Farmall 434 needs remotes!!! in reply to DieselAlbie, 09-10-2019 08:10:51
My email address is ; DieselAlbie@yahoo.com
DieselAlbie
09-10-2019 18:20:40
[quote="CVPost-jimb2"](quoted from post at 15:30:48 09/10/19) Hi, nice looking 434.
The photo below is of a home made remote hydraulic outlet for an IH 434
Thank you!!
I do not believe I have that manual, I can only find a service manual.
So that is just a pipe plug that I pull out and put a hydraulic line into?
jimb2
09-11-2019 07:20:56
 Re: HELP! Farmall 434 needs remotes!!! in reply to DieselAlbie, 09-10-2019 18:20:40
Hi, I have opened my email so you can send me your email address and I can email you the B414 Operator's Manual.
The major differences B414 vs 434 were sheet metal, 434 may have an alternator and be -VE ground, better brakes, larger disks brakes and a change to connection from pedal to brake actuator rod to give more leverage therefore requiring less foot pressure on brake pedal.
See link for using a remote cylinder on B414/434 using 3pt lever.
jimb2
09-10-2019 18:45:27
Yes, it is a pipe plug, I can't recall if it is 1/2 or 3/4 inch pipe thread, install a hydraulic hose with Quick Coupler to match the Quick Coupler on your Haybine.
Now Operations is a bit more complicated, it is described in the Operator's Manual, I have the Operator's Manual in PDF format for B414 that is one generation older than 434.
It is in 5 sections of 20 MBytes each, I can email it to you if you provide an email address, otherwise I can post the instructions for using the 3pt lever and Isolator valve to operate a remote hydraulic cylinder.
jimb2
09-10-2019 15:30:48
The photo below is of a home made remote hydraulic outlet for an IH 434.
I was going to put a link to caseih.com parts that was the official CIH parts to put a remote hydraulic outlet on a 434.
Do you have an Operator's Manual for 434 that describes how to use the 3pt lever with the Isolator valve to operate a remote hydraulic outlet?
DieselAlbie
09-10-2019 13:10:02
[quote="CVPost-jimb2"](quoted from post at 09:59:34 09/10/19) Hi again, yes it is a true UK or Canadian 434, we had one just like it from 1969 thru 1980.
I see it had a loader on it at one time.
Single Action would probably work good for the Haybine
jimb2
09-10-2019 09:59:34
Options for 1 remote:
1) single action, 1 Hydraulic hose lift up and gravity down and 3pt locked out when remote is active? Cheap only hose and couplers required but can't use 3pt at same time.
2) Add an external hydraulic valve either single or double acting(2 hoses up and down pressure)? More expensive, require external hydraulic valve, hoses and couplers but will be active all the time.
DieselAlbie
09-10-2019 09:36:39
It is the UK tractor, I really only need one remote for a Haybine
jimb2
09-10-2019 09:08:05
Hi, is this a UK built IH 434 Diesel tractor?
How many remotes do you require? 1 or 2 or more?
Do you require single or double acting remotes?
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
