Hi everyone, I recently bought a 3444 with a loader and 3pt (no backhoe). This has two pumps: one for the loader and another for 3 pt and power steering (from what I understand). Regular mechanical clutch transmission.
Before buying it, I inspected it thoroughly, no major leaks, hydraulics worked fine, ran it awhile, etc. Putting it on a trailer and hauling it 100 miles was hard on it. An appreciable leak appeared and pump started whining. Simply tightened the hose that was leaking to stop the leak.
While there are different variations of the 3444, according to the manual, the transmission and hydraulic reservoir are one single unit. The tiny dipstick located in front of the gear shifter showed no fluid on it, so I added Hy-Tran to bring the level up. Loader cylinders were retracted when I did this, 3 point was up, and the "isolation valve" was in "open" position. Started it up, and worked the air out of the system by lifting bucket several times. Worked great. Whining stopped and all was fine.
Next morning I find a puddle of fluid on the floor, from two new leaks, which appeared to be coming from both brake cylinder drums (it has brakes geared to the axle, not on the axle itself), which suggests that the seals for that shaft are shot on both sides. I need to change the brakes so I will confirm this soon.
Here is the interesting thing. I noticed that the 3 point also dropped down to bottom overnight. Perhaps that is normal since the isolation valve was in the "open" position. I then checked the fluid level: it showed over-filled. I start it up again and work the loader up and down. When the 3 point is in the bottom position, no pump whining. When I raise the 3 point and lift the bucket, there is lots of whining. I turn off the tractor and check the fluid again with the 3 point still raised. It barely registers any fluid on the stick. I drop the 3 point to see if that changes the level in the dipstick. It did not. Turn it on again, raise the 3 point and turn tractor off. Fluid on dipstick still read near nothing. This morning, the same observation is made: 3 point dropped down and fluid level now reads over-filled.
Does anyone have any ideas about what is happening? Fluid is milky with moisture, but I want to fix the leaks and any other hydraulic issues before I replace the fluid and filter.
Thanks!
Chad
Thanks!
Chad
