Farmall & IHC Tractors Discussion Forum |
IH 504 Hi-Clear with FEL
Author |
[Modern View] |
ajhbike
09-07-2019 01:44:15
I checked the hyd/tran oil level by opening the fill level plug (soooo conveniently located!). FEL, 3 point, and steering working well. I remember that when I asked the PO if he had recently checked the oil level he said his mechanic said that "if you open the the fill plug, stick your finger down there and you should fill it till you touch oil." That didn't make sense since I saw the height difference between finger level and the level plug, so I opened the level plug and 10 gallons of oil came out. So I got past my bad thoughts of him and now I am wondering if there should be more oil than the level plug indicates because of the FEL. I am getting some minor squeeling from the steering that I didn't have before. Should I add an extra gallon?
ajhbike
09-11-2019 12:21:19
Re: IH 504 Hi-Clear with FEL in reply to ajhbike, 09-07-2019 01:44:15
they are dual action cylinders and there is an engine pump. No water came out...the oil was actually reusable. I am going to add another gallon and see what happens.
ajhbike
09-07-2019 15:25:16
Just wondering if more oil is needed because of the lift cylinders= more volume
D Slater
09-07-2019 15:53:55
Re: IH 504 Hi-Clear with FEL in reply to ajhbike, 09-07-2019 15:25:16
If hydraulic cylinders have two hose plumbed to a cylinder little change would be seen in oil level from retracted to extended unless the cylinder rods are a bigger diameter than normal. One other thought is the suction pickup has a leak and they overfilled to keep air from entering the pump.
D Slater
09-07-2019 06:29:03
If I remember correct the 504 tractors could have a engine driven pump or internal housing pump. Thinking you must have a internal pump in the center housing as you describe checking the oil level. If so and the loader is operating with lift cylinders vented on one end the position of loader could effect the oil level. Not way over filled though.
ajhbike
09-07-2019 04:45:04
I check the manual it doesn't say how much extra oil or if extra oil is needed for a front end loader
Janicholson
09-07-2019 05:07:09
Re: IH 504 Hi-Clear with FEL in reply to ajhbike, 09-07-2019 04:45:04
Two comments, take them with the idea that I do not know that tractor. The finger in the hole is usually to find the minimum oil level, not where it should be. Which is in most cases just dripping from the check plug. Overfilling (if not leaking) is OK. Have you determined that it had no water in the system? If it has Hytran brand oil in it it would look milky. if other oils, the water could be filling the bottom of the housing. To check for water, the drain plugs (one at a time) are loosened to the point of leaking to see if water comes out instead of oil. Jim
Janicholson
09-07-2019 04:43:08
Before you operate the tractor, and doing so causes damage, find out if the hytran level, and amount are actually determined by that plug. that seems to be an excessive overfill, or the wrong information on checking the level. Third hand information is suspect. The tractor is unique enough to have an owners manual. Jim
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
